Advantech subfloor question
justinlacy | Posted in General Discussion on February 27, 2021 06:35pm
Just began construction on our new home, about 50 miles south of Houston TX. One thing about the house that is very uncommon around here is it will have a closed/unvented crawl space above a full slab foundation. There’s a 3′ tall CMU perimeter stem wall that supports all of the exterior walls. The interior load bearing walls are supported by 3′ tall 2×6 pony walls. All floor joists are 11-7/8″ BC I-joists.
The subfloor is 1-1/8″ Advantech, and is 95% installed. Unfortunately, a lot of the subfloor was laid without leaving at least a 1/8″ gap between the 4′ edges. Many are butted together. All total, the subfloor has about 120 sheets of Advantech (some having the gap), so pulling them up and reinstalling would be a tough task. I’m not even sure it could be done without tearing up the subfloor and I-joists.
I’m looking for a reasonable solution to this. The builder suggested running a circular saw with a thin blade (with the blade depth set correctly) down the 4′ edges to create the gap. I’m okay with this it will achieve the desired result. Is this a good idea? Any reason not to do this (other than it should have been done correctly the first time)? If this will work, is it more important to cut all the way thru the Advantech subfloor, or to not cut into the I-joist at all? In other words, is it better err on the side of cutting a little less than 1-1/8″ or cutting a little more than 1-1/8″?
  1. andythearkansawyer | Feb 27, 2021 10:03pm | #1
    I don't see the issue with this plan, and I would be sure to overcut into the next panel to complete the cut due to the round in the saw blade. it shouldn't matter if you slightly over or undershoot if the depth is set as accurately as possible.
    I used 3/4 advantech and they are tough material, I was impressed. I used some nails to ensure the gap at the 4 foot butt joints. This solution seems fine but if you don't complete the cut by overshooting, then I imagine whatever buckling that the manufacturer is trying to prevent with the ⅛ gap instruction won't be achieved because the material is very sturdy and that little bit in the saw curve could cause problems.
