Hardwood Stairs
MikeK50 | Posted in Construction Techniques on September 11, 2006 05:26am
I need some advice regarding renovating my existing stairs.
I am replacing my carpeted stairs with hardwood treads and the wrought iron railing with hardwood. The first 11 stairs from the top have walls on both sides, so I only need to install the handrails to the wall (no spindles or newel posts).  There is a small landing, with the last two steps at a right angle to the main flight.   I will need newel posts forming a right angle at the landing and at the bottom of the first floor.
I can buy all of the materials online or at Lowes, but I have never done stair work before.  I know that there are many tricks of the trade that will make this job go a lot easier.  Your help is greatly appreciated.
Some specific questions are:
1. Do I remove the existing stairs treads before installing the hardwood treads?
2. Do the toe-kicks go over or behind the stair treads?
3. What is the best way to anchor the newel posts?
Thanks,
Mike
  1. plumbbill | Sep 11, 2006 06:03am | #1
    1. Yes
    2. I prefer the risers in first so the tread helps hold it in place.
    3. Anchored to a structeral member is the best way---- would need to see some pics of what you have to work with to come up with the best anchoring method.
    "I'm here to chew bubble gum & kick azz, & I'm all out of bubble gum" Rowdy Roddy Piper
  2. wooddoug | Sep 11, 2006 06:51am | #2
    the idea is to end up with the same rise at the bottom and top steps that you have in the middle runs.  your carpet is about 3/8".and your tread underneath is probably 1"1/2  for a total existing thickness of17/8". your new oak tread is 1 1/4"remove the old carpet and old tread. build up your carriage 5/8", add oak tread.now if your rises were the same before they will still be the same. as for the handrailing, leave that for the proffesionals.
Picture-Perfect Pergola
