how to remove tile and reuse
kneetwoods | Posted in General Discussion on January 31, 2007 07:20am
Hello,
Anyone with tips to share on removing ceramic wall tile from drywall (I think). I want to remove some tiles  (to make a plumming repair) and then re-install them.
My questions are:
how best to remove tiles without breakage. I figure to remove 8 tiles in the center.
how to get adhesive off back of tile so I can re-use them.
Thanks for any insight
Bob
  1. calvin | Jan 31, 2007 07:27am | #1
    The first tile (in the middle rather than one on an open edge) has to be sacrificed.
    or, if you want to try it.  Take a utility knife and cut through the drywall (after removing the grout joint).  Block later and glue the whole shelonga onto the blocks.
    Another nifty spot for the multimaster..........
    http://www.quittintime.com/
    1. kneetwoods | Jan 31, 2007 07:31am | #2
      Thanks Calvin. I like that idea.
      PS are you the multimaster or is that a tool?
      1. calvin | Jan 31, 2007 07:33am | #3
        I've got a long way to go to achieve that status.
        However, I"ve got the multimaster and yes it's a tool from Fein.  A unique indespensible tool for the discerning carpenter.
        There's some threads in the Tool folder, check 'em out.A great place for Information, Comraderie, and a sucker punch.
