installing window A/C through stucco wal
user-295030 | Posted in Construction Techniques on June 9, 2003 06:35am
hey all, I am in the process of installing a window mount A/C  through a stucco wall.  The question that I have is how do I best keep moisture from penetrating from the exterior opening.  I am framing it so if I wanted to at a later time I could put a window in, but for now I want zero clearance between the A/C unit and the hole cut in the stucco.
Old House Air-Sealing Basics
