Is a starter strip needed when using rolled roofing instead of regular shingles?
ab12345 | Posted in Construction Techniques on May 16, 2011 01:54am
We are replacing the lower parts of the rolled roofing on our garage and was told at the store that we would not need a starter strip since we were using rolled roofing? Is that true?
Also, are we supposed to tar along the bottom edge of all of the rolled strips? I read somewhere that you tar two inches at the bottom,then lay the next section down and just nail int he top?
Any instructions on how to do this would be great.
  1. [email protected] | May 16, 2011 06:34pm | #1
    Where are you?
    To some degree it depends on where you are.
    Fill out your profile.
    MarkH | May 16, 2011 06:38pm | #2
    Here's a document that may help
    http://roofing.owenscorning.com/docs/installationinstructions/install_msr.pdf
    The document is from this website:  http://roofing.owenscorning.com/homeowner/shingles/mineral-surfaced-roll-roofing.aspx
  3. DanH | May 16, 2011 08:32pm | #3
    Used to be you used rolled roofing as the starter strip under shingles.
    hammer1 | May 22, 2011 10:42am | #4
    Installation instructions are on the package.
