PROPER NAME FOR WINDOWS
BIGJIM05 | Posted in General Discussion on February 14, 2006 02:33am
I need to replace some windows in my home and would like your help please.
What is the proper term when you want the windows to come together in a complete frame that just gets inserted in the old window opening?
I have a back bedroom with three windows in it and would like to just knock out the old and get a new group of three -ganged together and ready to shim in place.
Thanks for your help.
  1. Stilletto | Feb 14, 2006 02:37am | #1
    Type- Replacement Window,  Mulled together by the factory if possible
  2. MikeSmith | Feb 14, 2006 02:40am | #2
    when windows are joined they are termed "mulled"
    so two windows joined togerther would be a  "double mullion".. or a double mulled unit
    3 would be a triple mullion, or a triple mulled unit
    1. BIGJIM05 | Feb 14, 2006 02:44am | #3
      Are these "mulled" windows that uncommon since I cant find them in my local stores?
      And again thanks for answering so fast.
      1. dustinf | Feb 14, 2006 02:51am | #4
        Technically, the windows are ordered separately, and "mulled" together at the factory with a mullion strip.  It should be a small upcharge per mullion strip.
        Depending on the size of the opening, the window unit might be to large, to be shipped already mulled together.
        JeffBuck | Feb 14, 2006 03:20am | #5
        I doubt you're gonna find them at HD or Lowes ...
        any decent real lumber yard should have a guy that handles the window ordering ...
        that's the guy U wanna talk to.
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
      3. Piffin | Feb 14, 2006 06:22am | #6
        You mull on site or order factory mulled.
        1. BIGJIM05 | Feb 16, 2006 12:54am | #8
          Opinion please
          Would you feel it would be cheaper to order a triple mulled window and have it installed or just order three seperate windows and have them installed and any old wood just redone?
          1. Jer | Feb 16, 2006 01:20am | #9
            Triple mulled , because of labor.
          2. mbdyer | Feb 16, 2006 02:55am | #10
            What are the three units you're replacing? If they're not a triple unit you will have header issues requiring three singles instead. How are you going to set them in the window frame? Can you get a massive triple unit through the house and up into the room? Triples in new construction save time for the installer. Replacement jobs are often better done, if not only possible, with singles and the occasional double with help. Don't be enamored with factory mulled doubles or triples, they're often just a gang of singles stapled together with flimsy steel straps and 3/8" wood strips, maybe with a 3/4" head and sill board which is often only for "shipping". Perhaps three single units, liberal amounts of shims and some mullion stock will serve you better?
          3. MikeSmith | Feb 17, 2006 06:09am | #12
            most window mfrs also will mull with a structural pocket ...space between the units for a 2x to break the span of the header
            and , some also will mull with a  steel plate for structural support between the  unitsMike Smith Rhode Island : Design / Build / Repair / Restore
          4. Piffin | Feb 16, 2006 03:53am | #11
            Factory mulled, as a general rule, but there can be other factors, like time frame, materiasls and labor available, etc
      Huck | Feb 14, 2006 09:24am | #7
      Why didn't I know that?  Learn something new every day here!"he...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
