silicon for SYP Log siding ? no way
FDC | Posted in General Discussion on February 25, 2007 07:25am
Weve been using K.D. #1 southern yellow pine overlapping log siding over conventional frame, chip, tyvek.   We dont use the log corners that are avaliable but use 2X syp corners and trim. We use straight but joints at splices and trim.  With  the stain- sealant that will be used to finish the siding we butter the cut joints and overlaps before its nailed up.  Three houses no (BIG) problems so far.
Because the owner hasn’t decided on a stain sealer brand or color, the siding will be going up dry. The siding contractor suggests using clear silicon in the butt joints, hopefully the silicon wont be oozing out and visible.  Beside the fact that we never use silicon on bare wood and my concerns of trapping moisture, is there any merit to this suggestion? (before I step forward and nix this idea and make everyone mad…again).
FDC
  1. Stilletto | Feb 25, 2007 08:51pm | #1
    Silicone won't take stain of any kind.
    Just put flashing behind the joint that laps onto the course below it.
    BillHartmann | Feb 25, 2007 09:12pm | #2
    You should use a Paintable Water Repellant Protectant.
    I think that Jasco makes one that is clear.
    And there are some other brands.
    The protectant is a copper or tin based anti-fungal. That will reduce rot, mildew, and mold.
    And the water repellant is wax based, but no enough to keep it from being painted.
    Specially treat the end grain.
  3. AllTrade | Feb 26, 2007 02:41am | #3
    I would do what both bill and stilletto said treat ends and istall flashing. The ends will wick if left untreated. The flashing is fullproof.
