Window part needed..
Lateapex911 | Posted in General Discussion on February 23, 2005 04:31am
This is easy, although not to me I guess! I have tried to find, to no avail, some parts to redo my windows. I am looking for those little screw grommets that hold the interior sash stops in place. I need them in a silver variety.
Any ideas on a good source?? Mine are all painted or missing. Thanks!
Jake Gulick
[email protected]
CarriageHouse Design
Black Rock, CT
    coonass | Feb 23, 2005 04:52am | #1
    Jake,
    I am not sure what you're looking for but Blaine has lots of parts.
    http://www.blainewindow.com/
    KK
    SteveInCleveland | Feb 23, 2005 05:01am | #2
    Gotta a HD near you?  I just bought a box (quantity: 100, I think) two weeks ago.  Hanging in the screw/nail aisle.
    If not try Mcfeeleys:
    http://www.mcfeelys.com/subcat.asp?subcat=20.5.4
    Edited 2/22/2005 9:07 pm ET by steve-o
    1. Lateapex911 | Feb 23, 2005 07:03am | #3
      Thanks guys, the finishing washers in McFeely's are oh-so-close!
      But the existing ones I have are more like grommets. The screw sits down inside them, so nothing is projecting above the surface of the wood stop, except for the material thickness of the grommet flange. The hole in the bottom is actually a slot, presumabley for adjustment.
      It seems so common...but I just can't pin it down!Jake Gulick
      [email protected]
      Black Rock, CT
      1. ripmeister | Feb 23, 2005 08:01pm | #4
        I just used the finish washers you refered to.  If I recall they came in several sizes so that i just got one that was a little oversize such that the head was completely recessed.  A very close match to the original on my 1920s double hungs.
      2. DanH | Feb 24, 2005 06:48pm | #5
        I know what you're talking about -- it's a cup-shaped deal with an outer lip that overlaps the edge of the hole, and a hole in the bottom of the cup for the screw. The screw head sits entirely below the face of the trim. These were used for all sorts of removable trim in homes and business built roughly 1920-1950.Don't know what they would be called, unless it's "cup washer" or some such.
      3. BSayer | Feb 24, 2005 08:05pm | #6
        I believe the slot was to slid the window stop tight against the window in the winter, when it wouldn't be opened.You might try poking around here,
        http://www.oldhousejournal.com/restoration_directory/rd_home.shtml
        goldhiller | Feb 25, 2005 04:06am | #8
        I haven't looked at those finishing washers at McFeeley's and so don't know if those offered by Jamestown Distributors are different or not. SS, they are.You might also try Outwater Plastics. That's a maybe. http://www.outwater.com.Or visit your local upholstery businesses and/or auto trim ....and/or custom RV places.Or maybe try an upholsterer's supply website. How about here? http://www.google.com/search?hl=en&q=finish+washersKnowledge is power, but only if applied in a timely fashion.
  3. Stuart | Feb 24, 2005 09:22pm | #7
    You may want to look for one of those small, old-timey hardware stores in an older neighborhood. There's one down the street from my house that had them in stock when I needed some. I believe they're called "finishing cup washers," if you do a Google search you'll find a few places that sell them online - here's one example. http://www.cabinetmart.com/67.html
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
  • Townhouse Transformation
