Is this security system possible?
| Posted in General Discussion on December 31, 2000 07:50am
I know we typically do not address electrical and control systems here, but here goes:
Specification for Driveway Alert Security System
Concept:
Magnetic sensors are embedded adjacent the driveway near the entrance to the property from Algonquin Drive. The sensors send a signal to the system in the home when a vehicle enters the driveway. A vehicle exiting the driveway will not signal the system, nor will the passage of a human or animal.
Control is adjacent the service entrance inside the home.
The system can be controlled to perform various sequences of events or event combinations, when the magnetic sensors signal a vehicle entering the driveway.
The “When Home” event sequence.
A daylight sensor is installed outside the home, and in darkness conditions, front exterior lighting is turned on, and the single-tone doorbell is rung. The doorbell has two tones, a single tone (car entering driveway) and a double tone (front door button pushed). In daylight, only the single-tone doorbell is rung.
The “When Away and Set for Security” event sequence.
A vehicle entry initiates a timer, and after a first interval, upstairs bath and hall light turn on, after a second interval, staircase lighting turns on, and after a third interval, front hall lighting turns on. After a final interval, if outdoor lighting sensor says “darkness,” all outdoor lighting turns on. All lighting returns to off after one hour.
An “All Off” setting causes no events to trigger from a vehicle entrance.
Is this possible?
  1. GeneDavis | Dec 31, 2000 07:50am | #1
    Concept:
    Is this possible?
Versatile Vise
